when the 1080s are in stock ocuk are sending out 980tis instead of haribo![]()
lol ouch
ppl that got vr editions of the Ti i feel sorry for
I'll have several tabs open with the different sites I use to buy parts. F5 Bashing time...Problem is (if preorders start tomorrow) I'll be at work at 9am which is when I imagine you can preorder with no signal on my phoneMight have to take an early break. Taking my tablet to work to hopefully make it easier.
The hype has well and truly gripped me now, I'm such a weakling. Hoping I can snag 2.
I'm waiting for EVGA Custom GTX1080.
Hybrid 1080's are gonna be epic
Watercooling mine![]()
im wondering if its just best to Keep buying the "mid" ranged card from a pure perf/time/cost perspective
what i mean is buy
780 on release, cheaper than a Ti generally, skip ti
buy
980 on release cheaper than Ti generally skip Ti
buy
1080 on release cheaper than Ti generally skip Ti
i wonder if that actaully works out cheaper & better perf over time?
you get new tech quicker, cheaper unless of course you start at Ti.
770 released at the same price as the 670($400) - just $100 cheaper than the 680.It's probably a good idea to do this, but one step down. i.e.
Buy 770 - slightly faster than 680 for nearly half the price
Buy 970 - slightly faster than 780 Ti for under half the price
Buy 1070 - slightly faster than 980 Ti for nearly half the price
Say you budgeted about £1000 over 3 generations, doing this you'd end up with a 1070 (starting from the 7xx series), but you'd run out of money at the 980 under your example. And the 970 isn't that much slower than the 980, so I think this way works out better in the long run.
3Ghz?!
Not always. People wanting a 980Ti for SLI etc will pay for them. At that point the pricing of the 1080/70 doesn't matter. This will go on for a month or two after launch.
1070 launching at £375 don't forget. At equal performance, possibly less in areas won't drive the Ti down to £200.
780Ti's are STILL going for £150-200 on eBay.
