(Wales Velothon which looks like it is going to be 14 degrees with showers!). Over lunch have narrowed it down to these two:-
https://www.evanscycles.com/sportful-hot-pack-5-jacket-EV203900
https://www.evanscycles.com/endura-fs260-pro-adrenaline-race-cape-EV168770
Has anyone had experience with either of these or has any other recommendations? I am edging towards the Endura but want to check before I dive in. Ta
Hot Pack looks very similar to the Castelli Squadra for loads more pennies (pay for next day delivery & still cheaper)!? Although it might be more breathable fabric? This would certainly be more breathable.
The Squadra is good in showers and being thin doesn't get that toasty, has a few vents too, but I wouldn't wear it long-term as it would get 'boil in the bag'. For prolonged rain a more solid multi layer light jacket is best, it won't create condensation so you don't get as boil in the bag, better protection, but you do run the risk of it actually being quite warm if it's not got enough vents. I rate my DHB EQ2.5 as it has vents all around the torso and large underarm zips you can also open. Although I only tend to use it in heavy rain as temperatures much over 12 degrees it is warm. This Flashlight version is high viz (which was a requirement of mine) and seems more of a racier fit with similar features.
If it was me I'd have waterproof arm warmers and a windproof/waterproof gilet, just putting up with wet shoulders as I then wouldn't overheat. Keeping my feet/arse dry are more important to me as I generate lots of heat from my torso which dries out much of my upper body quite quickly. Overshoes! Overshoes! Overshoes!
Helmets. Kask.
Anyone got a Mojito and Vertigo (after differences?) or the Infinity and Protone? Or any general experiences really.
I think I want an Infinity so I can shut the vent in winter/rain, but I think most of the others have optional aero covers?
Although I could exchange my current Echelon II for an Evade as Specialized are doing their trade in...
