Caporegime
- 9 Nov 2009
- Planet Earth
Wow GP106 have 256 bit bus, about 4 TFLOPS and bus powered! That faster than GTX 970 and probably 75W TDP.
Look like GP108 will finally have 128 bit bus, about 2 TFLOPs, faster than GTX 950 and closer to GTX 960 performance on very tiny chip measured 87mm2 if it will still use same size as GK208 and GM108 while consume around 33W TDP or bigger chip around 100mm2 with less than 50W TDP.
GP108 could be AMD worst nightmare If GP108 can overclocked to achieve GTX 970 level performance to play VR without issues.
Are you on what Flopper takes??
I leaked the GP106 die picture earlier in the thread. It is a 200MM2 GPU,so around 60% of a GTX1080 so probably around GTX970 level.
Polaris 10 is 232MM2 on a denser process,and looks like it might be a tad faster going from the R9 390X level performance rumours for the 2304 shader SKU(Polaris 10 is rumoured to have 2516 shaders).
Polaris 11 is meant to be a tiny GPU,with at least GTX950 level performance - probably more R9 380 level which is generally a bit faster than a GTX960.
