Drivers will further increase the gap between the Titan X and 1080/1070 bit by bit every new release.
very nice mate, sometimes I miss SLI
make sure them EK compression fittings are on good, they have a tenancy to loosen![]()
I stopped using those fittings a lot time ago as I was making my fingers sore doing them up.
I prefer Monsson fittings these days as they come with a nice spanner to do them up.
@olliej82
That is a very nice clean and well laid out setup you have there.![]()
@olliej82
Got a chance to get a second TX with EVGA Hybrid for £500 (you know who you are), ahhhh really wanna max BF1 3440*1440 with no issues.
What overclocks are you guys running? If any one has a Titan X that is seems its all 1080 now..
I can get +195 core +300 mem with Stock Bios and Hybrid cooler..
i watched this was quite helpful he seems to be getting +250 core 400mem with full volts
https://www.youtube.com/watch?v=vUEMS-B1Siw
Seems when i over volt the boost just jumps around and will not stay steady
I've been hunting the bay for another one after selling my 2, buying a 980 then buying a TX again. There are a few less than 500 but I'm getting everyone to check the ASIC's for me after my last 2 were so low (such is my experience with ASIC's) I want one which is close to my new one. This is proving hard as mine is the highest I've ever seen. 84.7%.
Mine is happy to bench at 1547 and I think I can go higher.
Yes when matching cards in sil getting two cards with similar ASCI`s is a good idea if overclocking to the max.
If you can...has anyone seen many with an ASIC of over 80?
PS. Those who tell me ASIC doesn't matter, go away. For me it's made a difference.
I went through 9 Titan X's and not once had 80. In fact highest I got was 74.2%so yours is pretty incredible.
ASIC does seem to play a role IMO. I did however notice one Titan X at 71.2% and another at 69.3% the one with the higher ASIC used more volts however with the lesser ASIC number being able to clock higher so when the figures are close enough not always clear cut. But yeah in general my higher ASIC cards performed better general.
