The performance metric, the 970 and 980 have theroetical performance lower than 5Tflops.
Which is irrelevant to actual gaming performance
How so? That is less flops than the 390x. That says to me that it is going to be around 390x performance especially as it is being compared to the 970 and 980.
Apparent leaked slide, The figures put this at 980TI - Titan X if it is real.
And the 390X has 5.9Tflops at 1ghz and is already on the heals of a stock 980Ti.
Here he goes. But it gives you an indication of how the card performs.
Seems what a few of us expected but the question is there an RX 480X?
What else is on the market in this price segment. Nothing is the answer and they are not going to compare it to a gtx1080. These slides would have been made before the 10 series launch most likely. Even the 1070 is likely going to be priced £100 more than these.
Well GCN4 does bring a lot of improvements to the shaders and command processor, improving single threading in the command processor and shader utilisation through instruction pre-fetching etc.
So i expect Polaris parts to perform far closer if not at their Theoretical performance compared to GCN1-3 parts.
 the Raw shading power of Hawaii is similar to a 980TI however Nvidia's front end is far better which is why despite the raw power differences the 980TI beats the 390X by some 25%.
 the Raw shading power of Hawaii is similar to a 980TI however Nvidia's front end is far better which is why despite the raw power differences the 980TI beats the 390X by some 25%.Where are you seeing that?Apparent leaked slide, The figures put this at 980TI - Titan X if it is real.
GP106 will be the main competition. Nvidia have even released inoration amd die shots of it. That is where the debate really needs to be.
Here you go spouting irrelevant nonsense.
The 970-980 is clearly used as the comparisk which you are completely ignoring.
If you really want to focus on the TFLOPS then compare it to a 390x. And if you really want AMD to stay competitive you need to to stop over hyping their next GPU, it will be very damaging to AMD if people have false expections.
Polaris 10 is probably going to be a fantastic card. Absolutely no need to set it up for failure before it's launched
i dont think so, usualy the company showcase their best performing card first, in every launch they start with the highest they have, i have a feeling that this is their highest card, question is does it beat the 980 consistantly or does it trade blows.
If AMD rebuilt the front end to match Nvidia you will get higher performance in DX11 for the same number of shaders but less if any difference for DX12.
The same as Nvidia.
Yea, we'd be conflating AMD vs Nvidia flops basically. As enough have said already, 390X already has more flops than this.Gtx980ti is 5.6 Gflops and this 480 is 5.5. It's not really comparible unless the 480 can get close to using it's peak through put.
