- 11 Sep 2013
No, that's what I meant when I said it's *not* clear - There are cars in the lanes ahead and cars crossing your path halfway across the junction, blocking anything wider than 6". There is no space to filter through even on a bicycle.Because you can? Even if the area in front of the lights isn't clear, you can still filter your way through it
Some of these do have yellow hatch boxes, but not all of them.
I see bikes almost every day, filtering past and sometimed even right into this sort of mess, usually on motorway junction roundabouts. All they do is add to the traffic crowding, because there's nowhere for them to go either. Invariably the cars move forward too, leaving you trapped and collectively blocking the junction.
Just to be clear - Filtering I take to be going between two lanes of traffic in the same direction, rather than overtaking which is passing with one same direction on the left and oncoming traffic on the right.
I now stay as far as sensibly possible away from the side of traffic when filtering!
