Thats what am rooting for tbh Do AMD have something they not yet showing us?
A 40Cu and higher clocked version is only going to be about 20% faster. A great card for $300, still not 1070 ballpark, but solid performance for $80 cheaper.
Interesting. You work for one of AMD's AIB partners - do you have access to some sort of information there that we do not?I am considering a new build with an AMD 8320e and two 480's.
I have a theory that AMD's new feature GCN 4 feature set may point to better CPU utilization in DX11 games along with the DX12 benefits already available to it.
Any thoughts on that?
I can't quite see how even a single 480 would not be horribly, horribly gimped by an extremely low-end CPU like the 8320e, let alone dual 480s. It would certainly be interesting if what you're saying is true, as that would fix one of AMD's current gaping problems, and make the 480 appealing to a lot more people. That would be excellent news (for everyone except a friend of mine, who recently had to pick up a 960 for his AMD CPU system! Just a few more weeks and he could have had a 480!).
Are you under an NDA that is preventing you from giving more details? Can you at least give us a hint?
I was actually hoping for something more practical than theoretical! I know a lot of people here simply believe Nvidia and AMD's marketeers and press statements, but I've always preferred independent confirmation where possible.It comes from Raja explaining the new front end he was building for Polaris, some months ago.
It amounted to identifying and rectifying AMD's problem with batching.
Wasn't it Raja who also claimed a historic leap in performance per watt? Polaris looks to be far behind Pascal there if we assume that all of AMD's figures are accurate, and behind Maxwell if there's even the slightest exaggeration.
Which hints that AMD is only comparing with AMD, and so "rectifying" batching doesn't therefore mean that there will be a significant improvement compared with the market at large, only with AMD's earlier GPUs.
I don't think I'm being overly skeptical here - a 480 with a low-end AMD CPU? Not outside the realm of possibility - please tell me more. Two 480s with a low-end AMD CPU? That's.... revolutionary.
You should have reported the post that you found offensive Si instead of going with the personal attack. That isn't helping this thread at all again, pretty much like this post isn't.
Its hardly surprising that with so much unsubstantiated positive rumouring going on, there are going to be people who are a bit skeptical and ask for sources rather than just blindly accepting the most positive spin.
Yeah probably Greg, just found it ironic that the guy appeared a few weeks ago, basically trolled and stalked another forum member, then comes back begging for info lol, double standards much?
Anyhow, i was hoping to see some leaks by this weekend, guess not, whens the next show or event that AMD are attending? E3 is it? someone mentioned Hotchips also hopefully get more info then
Dont think anyone is blindly accepting anything. Just comparing/speculating on what little info there is so far.![]()
As he said, its unlikely AMD are using one GPU from the P10 SKU and calling it the plain 480, no X or XT or 5...
just as unlikely its just that one GPU with a 6 pin power connector.
This is also the $200, with "GPU's upto $300"
For more likely there is another version with two 6 pin connectors, higher clocked and with more shaders putting it more in the 1070 performance area for $300.
