They haven't said from what arch.
And digitimes is not a clickbait site. FFS I knew they'd delay it. They ALWAYS delay and screw up.
when they say 40% IPC increase they mean from the FX 9xxx series? if that is the case then it is too little too late.
FX 9xxx at 4.7GHz get 113 Single Core Score in CINEBENCH R15
Skylake at 4.7GHz get 204 Single Core Score in CINEBENCH R15
as we can see from cinebench, Skylake show almost double IPC.
Yes. Interestingly, that graph might suggest that they think they can improve Zen over the coming years by 15-20% in terms of IPC. It's more likely it's just a graphically nice arrow and they didn't put that much thought into its angle.![]()
I thought it was already stated to be 40% from Excavator?
.And the much-touted 14LPP is having problems with high frequencies.
I remember a similar thing being said about Polaris 10.
People claiming to have inside information that AMD couldn't get P10 on 14nm LPP above 850Mhz.
Soon debunked by AMD's response and then proof of the RX 480 running at 1266Mhz at Computex.
There seems to be a lot of people claiming to be in the know with insider information making hyperbolic claims, like Kyle from HardCOP for instance, one of the people perpetuating that myth and many others citing "insider information"
You can't trust any of it.
Ivybridge at 4.7GHz get 172 Single Core Score in CINEBENCH R15
So if we calculate the ipc gains from the AMD graph (excavator 7.4% + zen 40%) then the IPC will almost match the ivybridge.
zen at 4.7GHz(*) will get 170 Single Core Score in CINEBENCH R15
(*) assuming that it can clock at this frequency
Isn't excavator quite a bit more than 7.4% over Piledriver?
I thought it was more like a 10% increase from Piledriver to Steamroller, and then a further 8% from Steamroller to Excavator.
