Really struggling to make any progress on my lat pulldowns at the moment, they stalled badly before I took my hiatus from the gym, and its still an area I consider my weakest.
I don't have the strength for pullups as yet - is there any accessory work I can do to try and move these on a bit?
I'm sure the progression would have continued but I hurt my shoulder.Keeps your chest more upright and prevents you from losing thoracic tension.
Bodyweight squats 5x5 on Friday if all goes to plan (13st 2lbs, 82kg). After that, 100kg squats
Cheers very much
I pull conventional (hitching fine)
Deadlift every 9-10days (almost always same routine for DL but with boltons like partials or upper back seated rows about 100kg-120kg per stack depending on fatigue)
I peaked last year but at the moment have hit my ceiling and it just wont or rather I don't want to risk pulling bigger and getting a fail as negatives don't really do anything for deadlifting.
Anything wrong with using a narrow grip on bench (about 18 inches)? I feel a lot stronger doing that, or should I try and get used to a wider grip?
I've been following this plan for the past month or so, I sort of pieced it together from various articles and YouTube videos. I would appreciate any suggestions if there is anything I am missing/should not be doing.
Bicep dumbell curl 3x8 @ 8.5KG
Dumbell Press 3x8 @ 8.5KG
Overhead dumbell tricep extension 3x8 @ 10KG
Squat 3x8 @ 20KG
Bent over row 3x8 @ 20KG
I do this every other day and have been steadily adding weight each week. My own weight hasn't changed but I was losing about 1KG each week before I started through dieting, so hopefully something is happening.
5x5 seems popular here, is there any advantage to this that would be worth me changing what I'm currently doing?
