The Pascal GTX 1080 Owners Thread
What's the lowest boost clock and memory clock you can expect from a 1080 only adjusting power target? The results seem to vary quite a bit compared to 980ti?
Should be fine :). Mines just on +100.
Waiting for custom bios for the cards to push them up to some decent voltage.
Nice to hear what sort of OC's you are getting. I take it you got your new card then? :D
Yeah got the card :D
Seems to overclock ok, stuck at 2063 core (it starts higher) and 5500 memory, can go a little more on the memory but like to keep everything stable over maximum overclock.
In TW2 it's around 10fps faster at any given moment. Which is good really helps them low fps's
Overall the 1080 @ stock is 2% faster than my heavy O/C TX @ 1500mhz, O/C the 1080 to the above clocks it's 13% faster. Not ground breaking but for a swap money wise for TX hybrid I'd say it's worth it and won't devalue as fast.
Yeah its an upgrade especially if you can swap for TX without any cost or even pocket a little because the 1080 will hold its value for quite a while.
Both mine are sat at 2100mhz which im happy about. For me a good 20%+ faster than my Ti at about 1480mhz which i'll take especially as it helps for the lows and highs in games and once SLI drivers are fully working, that should amount to quite an increase.
got mine today
Welcome and on TROH.:)
The Roll of Honour.
Date 15/06/2016, Make EVGA Founders Edition, jabski, Link
Date 14/06/2016, Make MSI Gaming, Popov, Link
Date 14/06/2016, Make EVGA Founders Edition, Devious, Link
Date 14/06/2016, Make EVGA Founders Edition, Stelly, Link
Date 13/06/2016, Make Inno3D Founders Edition, CEUOTC, Link
Date 13/06/2016, Make MSI Gaming, JABenedicic, Link
Date 13/06/2016, Make MSI Gaming, Cochran, Link
Date 13/06/2016, Make MSI Gaming, JLyte, Link
Date 11/06/2016, Make Zotac Founders Edition, avatar12m, Link
Date 11/06/2016, Make EVGA Founders Edition, crinkleshoes, Link
Date 10/06/2016, Make Gigabyte G1 Gaming, BriT, Link
Date 09/06/2016, Make EVGA Founders Edition, spiralz, Link
Date 09/06/2016, Make Gigabyte Founders Edition, WesleyBurns, Link
Date 08/06/2016, Make Gigabyte G1 Gaming, Gregster, Link
Date 08/06/2016, Make Zotac Founders Edition, Biffa, Link
Date 07/06/2016, Make Gigabyte G1 Gaming, Sasahara, Link
Date 06/06/2016, Make EVGA Founders Edition, Boomstick777, Link
Date 06/06/2016, Make EVGA Founders Edition, tyler_jrb, Link
Date 05/06/2016, Make EVGA Founders Edition, danw872, Link
Date 04/06/2016, Make MSI Founders Edition, easyrider, Link
Date 04/06/2016, Make Inno3D HerculeZ X2, LewisRaz, Link
Date 03/06/2016, Make MSI Founders Edition, DAIR, Link
Date 03/06/2016, Make Palit Founders Edition, Spikey, Link
Date 02/06/2016, Make EVGA Founders Edition, Radox-0, Link
Date 31/05/2016, Make EVGA Founders Edition, toon_mad, Link
Date 31/05/2016, Make Zotac Founders Edition, ToastedChip, Link
Date 29/05/2016, Make Gigabyte Founders Edition, kitkat9933, Link
Date 28/05/2016, Make EVGA Founders Edition, X-Mikuru_Beam-X, Link
Date 28/05/2016, Make Gigabyte Founders Edition, dvs8, Link
Date 28/05/2016, Make EVGA Founders Edition, passey89, Link
Date 28/05/2016, Make MSI Founders Edition, Biomorphs, Link
Date 28/05/2016, Make EVGA Founders Edition, RichardH754, Link
To get on the Roll of Honour all you have to do is post a pic with your user name on it of your GTX 1080.​
Got mine about a week ago. Couldn't take a picture though with my s7 being broke so here we go!
Also after getting this card I was just browsing monitors, and the next thing I knew I bought a 1440p rog swift! How does that work?
From the response I got it seems it was a mess up by DPD as my package was not picked up either.
Turns out the idiot from DPD picked up the wrong Trailer, what a muppet.
Haven't had an email saying the new delivery date is tomorrow, Hope those of us affected don't have to wait long as it's a bit annoying to say the least.
Currently no matter what mod, including changing VRM with ASUS Power Card or similar is allowing more voltage or "power limit" in 3D. No Bios either. 1.25v is your lot.
Something internal to the GPU is locking this down or something within the driver or both. Currently no board partner has the ability to change any of these limits.
Going well so far. managed to get over 21k Firestrike
That's a very nice score. Your Physics score is nice for 4.625 Ghz. How high is the cache and Ram?
Here's mine, MSI FE, excuse the case half put back together.
For half the case only being put together, looks very pretty :D The interior of those cases are so nice and tidy!
Thanks :p
Indeed they are... the EVGA GTX 1080 ACX 3.0 was on order for £564 whereas all other models (F.E cards too) were set at £638 - and still are.
Certainly I will ;)
Yup... same here... I got my EVGA FE cards for just a shade under £500 each and now they are nearly £580!
