more people complaining about the coil whine than the fan issue. Shame.
What fan issue are you referring to? I'm aware of the one with the founders edition which was supposedly fixed with a driver update...
Hi there
Just an update, OcUK is now listing 50 GTX 1080's, that's twice the amount of our nearest competitor, infact more!
Like a boss!!!![]()
wow you literally can't be bothered to read the other posts on this page
Or maybe I've followed just over 100 pages and missed that bit. Why so angry?
Also no Reddit access where I am![]()
first wave of Gigabyte Xtreme reach USA yesterday but unfortunately some owners reported same QC problem with the middle fan hitting the X bar logo in front of it.
I'm hoping for that too, it seems that not everybody is having the issue.I'll be rather annoyed if having waited all this time I get an annoying noise from some misalignment. Hopefully it is just a vocal minority and we won't get those issues!
On the plus side those clocks sound good.
Worrying all the same but those boost clocks are impressive so very interested to see what these cards are capable of. Can't wait to get mine.
Well my Inno3D 4x Air Boss has arrived. Must say it is a very sexy card. One thing noticed though, is there were no adaptors, cables included with it, even though there was a cut out for them in the box. Just the card, and license / DVD stuff, oh and Haribo.
No reason not to do a clean install via DDU IMO. Only takes a couple of minutes and gives you peace of mind that you won't get any issues resulting from driver nonsense.Expecting a GLH today, apparently the 1080 driver is the same as the one I currently have for my GTX 760 - does anyone recommend uninstalling everything with DDU or not bother since its the same driver?
I'm a little concerned because my Acer Predator XB270HUDbmiprz only goes up to 120hz instead of 144hz - OC say its probably the card, Asus say it should handle it so perhaps a full driver reinstall is in order when I put it in?
Switched a GLH order to a Golden Sample a few hours back, and was told it should ship today.
It's the cooler operation that interests me more than the factory clocks.
Hasn't moved yet though, which isn't a great sign. Will wait and see.
Great stuff! Can you add a sub section on the shop site for FE and non-FE cards? That would help a lot when checking stock.
Still July for the FTWs I presume?
I'm 192th in line for my FTW so hopefully I should have mine by Xmas.
