yes its supposed to be released also on the 29th; with leaked benches it supposed to sit around 290/970 speeds......
Yeah, I saw those, it just seems odd that there haven't been any listings anywhere, and we still don't know how many CUs it has.
Is the 470 expected to come out on the 29th too? Some sites are saying yes, but there's a distinct lack of leaks compared to the 480, even though we have more official performance figures from AMD. I haven't seen any listings or photos of the card as yet either, aside from the one AMD showed.
If the UK price gouging for the 480 turns out to be too much and the 470 isn't too cut down I'll go for that instead. I'm not paying more than £200 for a graphics card, and the cut down model is often better value than the full one (see 970 vs 980, 290 vs 290x and 380 vs 380x).
I am sure I read the RX470 and 460 were coming later (like August time).
I think we will only be seeing Rx480's next week.
no you had someone say in their blog they thought; but didn't know...
Does the ref 480 come with backplate?
Seems like some will and some won't. Sapphire and XFX models have been pictured with backplates, whilst others have been pictured without them.Does the ref 480 come with backplate?
sep dollar never converts 1:1as the msrp is 229 not 239....
right now if you convert 229 to pounds its 155.93 X 30% vat would put it at 202.75 - add in 10% puts it at 222.75. now put that at 15% its 232.78 roughly.
if my VAT is off and its 20% then its 187.15; and if you add in 10 margins its 205.87; with 15% margins its 218.03.
If they went with 20% margins is where it starts gouging. You can't go 1:1 with the pound and dollar as the pound is worth more - until the pound drops......its simple economics.....so again stop trying to raise the price.
hell even with 20% margins its only 224.58which falls in most likely we'll see 8g version at max 220 more likely some models cheaper......and 4g version under 200....
Just so people know our landed cost on 8G version is over $200 !!!
Did AMD announce 8G at $199 or 4G?
£300 incoming.
Two things point to this being most likely inaccurate.
Therefore if 470 was equivelant to 970 speeds AMD would list it as VR ready, the fact they don't indicated below 970 speeds for RX 470.
- 970 is listed as minimum spec for VR ready.
- AMD do not list RX470 as VR ready (it's borderline according to them).
VAt is 20% so it's £205 with the same 10% extra the 1080 has, less than that without it. However the 10% isn't OCUK's margin.
When say Curries or something sell a TV with a £499 RRP, they don't buy it for £499 then try and sell it for 10% to make a 10% profit. The £499 price factors in a cut for distributors, shipping and retailer mark up. Adding extra on top of the RRP means EXTRA profit, not the only profit.
I thought AMD were supposed to be good with VR?
Well as long as it outperforms my 290x at 1440p by a good margin count me in, I might even get a second if it's priced at £200.
