How are people finding the flavour from Rejuiced? Received a batch (steeping for over 2 weeks) with very little flavour.
My new setup, at least until the Crown II is in the wild. Been chain vaping this bad boy since 7am, 13 hours later its still got 51% battery.
What mod is that?
Same here - I am absolutely convinced that one of the lab technicians is making mistakes. As you'll see from my posts earlier, I've had several batches of most flavours.
Some of the juices received taste of nothing but VG, at first I thought they needed steeping, but occasional bottles just do not develop. The current one I have an issue with is "NRG" which is meant to be energy drink flavour, which you think even without steeping would taste of something - nope.
I contacted Rejuiced and was duly fobbed off telling me to steep for a week, but they tactfully avoided my question challenging them that the very same flavours I had ordered prior tasted OK from the outset.
From research I've seen Rejuiced state that;
Menthols - usually good to go from the off
Fruits - benefit from 1 week steep
Desserts/custards - benefit from 2 weeks steep
In short, again I am almost sure now that this is not steeping issues, but mixing issues. I have 10 bottles of various flavours steeping, 1 week so far, including the NRG one I mentioned. If after 2 weeks it doesnt change, Im going to contact Rejuiced. If I dont get a satisfactory response I'll be making a post on Reddit as well as their social page to publicly challenge them.
Which flavours have you found muted? The other thing I'll add is, I think overall there is less flavour but can mostly get away with that given the price. I find some premium juices over powering in contrast. I've yet to try their extra flavour shots, perhaps this is the missing link, some flavours nding the and others not?
Speaking of Rejuiced....
Had these since April, only tried cherries and berries which was 'ok' but the others just don't seem to mix, and i took this after they've been shaken.
Thoughts?
Sigelei 213 + Kanger Toptank.
Whats the Sigelei like?
Been looking to replace my Fuchai for a dual battery which is slightly more ergonomic and compact, was originally looking at the Cuboid but im happy to consider other options
I like the Sigelei 213 - much nicer than the Cuboid IMO - the matte finish feels nice in your hand.
The buttons take a moment to get used to as they are quite flush with the unit, so you can miss them when you first start using it if you're not looking - but it only took a couple of hours to get used to it.
Just don't use it on TCR mode![]()
So I bought an Istick Pico, that came with a battery (18650). Now I have a spare at home, and went to plug it in to charge it last night. But it doesn't fit, I thought the numbering denoted the dimensions. Are some of them different?
If so, can anyone recommend one to get? Having a spare is handy, don't want to go back to the cigs :/
I've been making my own juice now for over a year, I sell 100ml to my mates for £10 - I make it up for about £6-7 so I'm making a bit of cash on the side.
If you're happy spending £43 on 240ml's of 'premium juice' then be my guest, but I think that if people saw how easy it was to create/mix your own, they'd soon jump ship.
I've got VTC5s in both of mine. Some 18650s are wider than others. Not tried any of the bigger 30Qs in one.
It's too tall. The lid won't shut, the battery with it has a flusher end than my other.
Thanks, shall have a look.
