- 8 Feb 2009
- Sheffield
It's too tall. The lid won't shut, the battery with it has a flusher end than my other.
Thanks, shall have a look.
If it is a flat top, as others asked, is there much distance between the cap's threads and the body? The pin at the bottom is spring loaded, so you might be able to push it down a bit as you turn the cap.
- I could've given you recipes for all three of those!
In future will check out all the concentrates before I order shouldn't take me long to develop a muscle memory of which are safe etc. Thanks Gee
