He means because he used artistic license to give it some character and differentiate it from the masses![]()
and the first link in the "Long run" from CPU to 240 Radiator
Ahh I've seen that idea somewhere else recently
I'm quite surprised you've had such issues bending the PETG, is your rubber a bit loose?
I really like this. always liked the idea of a custom loop just it scares the living daylights out of me.
where in Aberdeen are you? Ive got family north of Aberdeen in Banff
Looking well, I'm in the same boat, not going to the extend you have with hard lines but going water none the less. Upgrading from a similar spec too!
Here is the start of my 2016 build! https://forums.overclockers.co.uk/showthread.php?t=18739875
Can I ask, are you building this in your place of work?
Not sure if you'll need (want is different!) more than a single 980Ti to be honest. I'm running 2560x1440 on my middle screen and the games I'm playing are all at full detail and not suffering at the moment. I'm not doing 3D or VR though - which would probably up the power requirement. Might be an idea to wait for the 1080Ti to drop.
Cat on the exhaust is far better than cat on the intake - at least the fur stays outside! My issue would be that, in the photo, it looks like you're about to be gifted a more fragrant sort of feline deposit![]()
