Doom Vulkan vs Open GL performance
7 Aug 2014
Any capture tools for video for amd cards in vulkan? No luck with obs or maybe I have wrong settings or something.
I was able to use OBS in display capture mode. But the game has to be set to borderless with vsync on for that to work (all hell :)cool:) breaks loose otherwise). AMDMatt says he managed to use Action in borderless mode (edit: as above! ^).
8 May 2014
france
You AMD guys need FastSync. Really does work a treat :cool:
placebo effect much :D
there is a reason why no one did a review on fastsync yet, something isn't working as intended, and nvidia is holding reviews on that feature for now.
or if you could do a review that would be great, just add latency to the OSD, and compare it between Vsync/double/tripple buffering, and for tearing testing you play a game and turn the camera in circles, then reduce the speed of the video recorded to have an easy way to spot tearing.
it would be really interesting, and i am sure you will get HUGE viewing on youtube, since you will be the only one, i think you can easily get few hundred thousand view or couple millions.
Man of Honour
13 Oct 2006
or if you could do a review that would be great, just add latency to the OSD, and compare it between Vsync/double/tripple buffering, it would be really interesting, and i am sure you will get HUGE viewing on youtube, since you will be the only one.
It works really well if you are running a 144Hz sync and capable of around 180+fps when you need it - but in most other situations falls apart atleast on the setups I've been able to try it on 60Hz has been a complete stutter fest and 120Hz intermittently falls apart. In conjunction with G-Sync 1-2 racing games ran quite nicely with it even when they were dropping framerate as well - really really smooth and responsive in situations that usually you'd feel the input lag as they seemed to be recovering faster from drops in those moments when lots was happening. (Not sure why those games particularly benefited but probably some technical reason).
25 Nov 2011
The KOP
I see fast sync has just a fancy word for limiting the frame rate. Instead of using vsync, use fast sync.
On amd the user is best using FRTC and limited the frame rate just below the max refresh rate.
From my reading fast sync can only work if your frame rate is well above the refresh rate of the monitor and if the frame rate drops randomly in and out of the max refresh rate you get horrible stutter.
Gregster must run all his games well over his 140hz 1080 is powerful and all that.
Permabanned
12 Sep 2013
Knowhere
I used Mirillis Action, AMD APP, run the game in borderless window mode. 15FPS performance hit.
Note: The free version has a watermark.
I wish I'd never bothered buying Fraps, It insists in reducing my fps to around 30 even on games that run in the 70's & 80's when just playing, It never used to do it but I've since given up on doing vid's anyway, I did try the free version of Mirillis a while back but still hold out hope for AMD to offer something with a small performance hit like Nvidia do.
Man of Honour
13 Oct 2006
It isn't just limiting framerate - its a mechanism that allows a game to potentially generate a new valid frame much earlier than normally possible in vsync capped situations and with much better results (when it is working) than any kind of framerate cap in conjunction with vsync.
10 Nov 2009
Southampton
Except fast sync doesn't limit the framerate at all, and due to having a ridiculously small (less than 1 frame) delay, results in no input lag.
Fast Sync lets the GPU render as much as it wants, and only sends exactly as many frames per second to the display as are required to match the refresh rate (only when framerate > refresh rate, obviously), but doesn't improve framepacing like G-sync does.
Also, it works on any display. Not just piddly monitors.
25 Nov 2011
The KOP
Yes I know, while it doesn't work the same way a normal frame limiter would like vsync the outcome is the same.
Vsync adds input lag, while fast sync removes this. Both add stutter though much worst than input lag.
The best way is just disable vsync if running Gsync or freesync and limit the frame rate one below Max refresh rate. Zero input lag and no stutter.
Fast sync will only benefit people without Gsync and who can keep a solid frame rate above there max refresh rate.
27 Dec 2014
Southampton
hmm, can't find an option to enable Vulkan, I am guessing my Doom runs on OpenGL.
Playing in 3600 x 2036, Ultra and Nightmare I was getting between 70 and 98 FPS.
Running 368.69 drivers, through Steam and Doom demo, I've seen the option to choose between Vulkan and OpenGL right above the custom settings in Gregster's videos. I have nothing above that so I am either missing something obvious or I need to buy the game for that option to appear.
I ran it in 1080 just for kicks and laughs, I saw numbers between 90 and 190 fps, averaging at about 160 most of the time. Had to turn off G-Sync though otherwise I was locked at 60 fps
7 Feb 2015
South West
Most likely not supported in the demo.
Caporegime
24 Sep 2008
Essex innit!
FastSync DOES NOT limit the frame rate. Seriously, your last few posts are massively wrong bud and you should really have a read up on what FastSync does. When I go over my 144Hz refresh rate, FastSync kicks in and does a fantastic job according to my eyes. No tearing and no stuttering that I have ever noticed anyways and that's where it is at for me.
25 Nov 2011
The KOP
I know lol
For the last time, it's benefit is to remove screen tear and input lag, but has the same trade off has vsync that it can stutter real bad if you drop the frame rate below refresh rate.
It doesn't matter if it don't limit the frame rate. It's method is very similar.
FastSync
144hz @180fps = perfectly matched frames @144fps = no screen tear or input lag. Chance of stuttering
Vsync
144hz @180fps = perfectly matched frames no screen tear but does have input lag and stutter.
Limited frame rate. With either Gsync or freesync
144hz @180fps = perfectly matched frames no screen tear, no input lag or stutter.
End of the day, it doesn't matter if it's limited frame rate the outcome remains the same. It's just another method of removing vsync stutter & input lag only any use to someone without Gsync or freesync.
