- 27 Mar 2013
Cleisthenes - Not me, but now I need to find this doppleganger, kill him and absorb his powers until I am the last one remaining - THERE CAN ONLY BE ONE!!!!
Housey - There's two issues with Audi's OEM ceramics for me -
1. Mainly cost at £14000 new or £6000 for an unknown quality 2nd hand set.
2. Audi's V10 RS6/V12 Q7 1st Gen ceramics made by Alcon not being ideal for track driving which I'll be doing more of now.
Audi's ceramic design for the V10 RS6 and Q7 V12 TDI is made by Alcon and are a 1st Gen CCM laminate design (thin ceramic faces with a carbon/ceramic core) which copes really well when it's allowed to cool after a few minutes of hooning (i.e. perfect for the road) but on the track you keep the temps at 800-900'c (ceramics operating temp) and if you do that for more than about 10 minutes without stopping then the laminate resin starts to fail and the layers separate without you being able to feel the difference until it's too late.
After it separates the harder "ceramic" layer can't pass the heat on to the carbon core as well as before and it starts to oxidise and smear the ceramic layer as the temps rise above 900'c. Then you're left with a minimum £6k-8k bill to replace the front discs and pads or £14k if it's all four need doing.
As not many RS6's go on the track it's not a well documented issue but there's a few on forums that have a killed a set going around the 'Ring'. I'm happy with having to spend £600 on a new set of steel discs which will tell me when they're getting too hot.
From what I gather chatting to SGL Carbon who makes & refurbs C/Sic CCM discs, those particular V10//V12 Audi brakes used a thinner Ceramic face than other manufacturers (cost saving) and are more effected by this than someone like Porsche who use a different process for their discs (PCCB rather than CCM etc).
They've since changed their manufacturer from Alcon to Brembo and are now "better" but still using CCM process so not as good as other car makers on the track.
I always thought that regardless of manufacturer, for track ceramics are a bad idea (i like the idea of no/little brake dust just not the cost).
