The Pascal Titan X and XP Owners Thread
24 Aug 2013
Lincolnshire
So you didnt feel SLI 1080s would beat out the Titan then? At the prices right now I could do the same as you with my pair of 1080 FTWs and more than pay for the Titan... Its tempting but i'm not sure its worth it.
Presume you just wanted the Titan because its totally bad ass top of range?
1080 SLI beats a single TXP but obviously for unsupported games it will be a good 30% behind.
Will be buying TXP myself in a few weeks. Once blocks are released and in my hands anyway :)
10 Nov 2006
Lincolnshire
It eats my old 1080 @ 2088 for breakfast. Runs 1850 out the box and I've got it up to 2076 stable on benching. Runs @ 77c max on loop between 2000-2050 mostly full load after 30mins. Don't think it'll do much more on air needs to be under water but I'm betting it'll see 2.2 when it is.
24 Aug 2013
Lincolnshire
Wow nice! Sure looks like a monster of a card here. Can't wait to get them in my rig now. Under water lets see what these can do. Should absolutely fly!
Just to ask, can you confirm there are no warranty stickers on the screws?
Got any gaming comparisons etc? :)
4 Dec 2015
London
So you're offloading both 1080s for the single card then, it is tempting I will admit... But i'm still on the fence ;)
24 Aug 2013
Lincolnshire
Single card!?
SLI baby :p:D
11 May 2014
Edinburgh
Are there any gaming benchmarks with this card yet?
Comparisons etc. Just saw some fire strike results get posted and I am impressed
edit: found some :) Very nice
17 Feb 2014
bedfordshire
Tried the division on the main monitor X34 3440x1440
my 1080 with 5960x (main rig) gets around 59fps avg on ultra settings
my Titan XP with 5820K (HTPC) Got around 75fps avg on ultra when hooked upto the same monitor
10 Nov 2006
Lincolnshire
Right done some testing, temps aren't really a problem with this card as such, yeah water will help no end but the clocks are getting cut down due to power.
A modded bios is what it needs, my card tops out at 2078/5600 with 120% power no added volts hitting 77C. It clocks on air near identical to my 1080 running 2ghz+ 95% of the time.
Really looking forward to putting it under water adding a proper bios and some volts to see what it can do.
Caporegime
20 Jan 2005
Co Durham
I didn't really want two 1080s but ended up with them cause of preorders.
No experience of sli and I know people mention micro stutter plus if a game doesn't support it then performance will be way short of a Titan.
As far as ownership goes, I reckon both will lose the same amount of money. Titans will be worth half in a year but then so will 1080s
Plus less to cool and only one water block to buy so the Titan is going to be cheaper.
I've always believed that one card is better than two
24 Aug 2013
Lincolnshire
TDP shouldnt matter? Even though my 1080's power limit is 120% in afterburner they can push all the way to 135% without dropping clocks.
Rest sounds good :)
And yeah there will be some modded bios for sure before long.
10 Nov 2006
Lincolnshire
Rest sounds good :)
Sorry not TDP I meant volts.
220core and 600 memory for the above clocks, the memory wasn't even throttling the scores at that either.
