 - 23 Oct 2013
I have a lci m135i so it came with bus nav.  I decided not to get the pro as there's no way to upload speed cameras to it, so I was expecting to keep using my TomTom as a satnav, which I've found myself doing from time to time.  So, personally, i wouldn't stress about the pro nav - but, yeah, it's a bit crazy using a tomtom when the car has a built in sat nav.
Afaik, the pro nav gives you a bigger screen, and with that, you can have a split screen with 2 menus/screens running together. On the Lci (might be true on the earlier cars too), i think it also adds a load of connectivity options (web browser, remote app) plus changes the cd player to a dvd - i think...
Audio options - 3 steps: standard, advance and HK. I've got the HK which is v good, but not sat in a pauper-spec car to compare. I think it's only a speaker choice, so all have usb input for mp3s and I think the newer LCI cars allow bluetooth streaming without the need for pro nav (not too sure tho).
