*** The Official Xbox One Thread ***
^ Damn my mrs xbox has that very same issue! I'll try the fixes but I dont think it will help (out of warranty too)
I've preordered an xbox one S 500gb with Fifa 17 for £250 from zavvi, 10 % off too using code WELCOME so will be £225, then ~ £190 once I sell the game :O.
Here's hoping they let me use the deal!
Even if they dont I think a 500gb xbox one + game @£250 is better than the Gears of war 4 console @£400
Note 500gb xbox one S release date 22nd September
How do you remove '0' achievement games from the list on Xbox one?
On the 360 you could delete them, I read that they are removed automatically on the Xbone if you don't play them/play other games after but that doesn't appear to be the case.
I know it's not a big deal but it annoys me :)
That option isn't available on the Xbox One as yet
Does anyone know of an actual working fix for the intermittent controller problem? Have had it nearly a year now to the point where I only use my X1 via IR remote for TV/Catchup etc. :/. Really want to play gears 4 but don't think it warrants buying an S!
I just have a 5m usb lead connected all the time, it was driving me nuts going on and off all the ** No disguised swearing - EVH ** time.
Hi
Has anyone ordered direct from MS before?
Im unsure where to preorder the xbox one s 500gb version, was thinking perhaps direct from MS, but Im unsure what there like.
Thanks
Hi
Thanks
Yes I ordered the 2tb Xbox s direct from MS and it arrived on launch day .. No issues
I have also ordered a surface pro from them in the past and was posted super quick
Good to know. Thanks
Im aware the xbox can't currently bitstream dtshd/truehd. If I connect the xbox to my denon avr receiver via hdmi and set the xbox to send via pcm would it be just the same?
I did read something about if using pcm the night mode sound function on the receiver will not function, maybe I'm confusing that with something else.
No it outputs in DTS .. I have a denon Reciever and atmos speakers and it's annoying that the Xbox doesn't support the atmos on uhd films
Ah ok:D, not ever had a Seagate external, much difference between them or is just the price point being better.
The one I suggested is 7200rpm and powered externally and the WD one you are looking at is 5400rpm USB powered. I've had three of the Seagate ones for a few years now and they are still working fine.
The price seems to have gone up by a tenner since I last ordered one. Brexit. :D
Ah ok, Im really looking for usb powered as Im trying to declutter my media area as much as I can.
