My instructions said "please ignore previous instructions and DO NOT use pliers"
They must have made an amendment since the first ones went out
Looking forward to my temps then in the same case. Ive got a 420 Nemesis Black ice GTX in the roof on push/pull and a mayhems monsta 360 in the floor and another blackice GTS240 at the front and still undecided whether to plum in the 280 GTS in or leave it out. All fans Vardar f4 ER either 140mm or 120mm.
AFter seeing your figures I think I'll leave the 280 out. It was all getting a big crowded in the case anyway![]()
I think you should do well then with those rads fella
Lol guessing a few people may have destroyed their cards then.
plum it in. Cant have enough. 32c is a good temp although id be suprised if it is still 32c with the loop fully warmed and say the card at full load for a good 20-30minutes.
Unless you live in the antarctic.
well card was mostly at full load for over a hour with benching + was a little colder then usual last night , that being said i do expect it to rise a little when have a full session one of the evenings
really pleased with card and extra performance it provides at 4k with games tested so far , as i sit here typing this card is idling nicely at 21 / 22c with fans turned fully down.
