- 27 Apr 2004
- In bed with your sister
Made a scratch post for my neighbour's new cat.
Probably should have worn gloves
i see your scratching post and raise you the scratching post i made at the weekend.
not bad for less than £10 on the log and some tapping coach bolts (plank was kicking around the garden).
sorry for the image quality.![]()
(It was for indoors so couldn't get away with your "rustic" design).i see your scratching post and raise you the scratching post i made at the weekend.
and had either been 'jimmying' it or just using the up & over.
Finally replaced the mortice lock on the garage door. Levers fell in around 2.5 years agoand had either been 'jimmying' it or just using the up & over.
10 minute job but just 'one of those' things that takes forever to get around to doing.
Had to chop a little of the recess as the previous lock had a rounded fascia rather than rectangular.
Well done!
Out of interest, is that a Yale Locks PM560CH25 Hi-Security BS 5 Lever Mortice Sash Lock, or one of their better ones?
Thanks!
Set up the Turbo Trainer in the garage on my spare MTB
