The Pascal Titan X and XP Owners Thread
hellooo ...troh possible? THANKS !!!
[/IMG]
Just a quick picture of my two blocked, with backplates and ready to go into my project build, once I finish the changes!
Cheers
Ras
[/IMG]
Welcome and on TROH.:)
The Roll of Honour.
Date 03/09/2016, Make NVidia Founders Edition, Gudu55, Link
Date 31/08/2016, Make NVidia Founders Edition, marcus2704, Link
Date 26/08/2016, Make NVidia Founders Edition, tyler_jrb, Link
Date 23/08/2016, Make NVidia Founders Edition, fenchu, Link
Date 23/08/2016, Make NVidia Founders Edition, SonicB0000M, Link
Date 22/08/2016, Make NVidia Founders Edition, tipes, Link
Date 20/08/2016, Make NVidia Founders Edition, Kered_Dub, Link
Date 10/08/2016, Make NVidia Founders Edition, Stunted, Link
Date 10/08/2016, Make NVidia Founders Edition, Mark_D, Link
Date 09/08/2016, Make NVidia Founders Edition, Zping, Link
Date 09/08/2016, Make NVidia Founders Edition, Trunkey, Link
Date 09/08/2016, Make NVidia Founders Edition, VEGACORTEZ, Link
Date 08/08/2016, Make NVidia Founders Edition, crinkleshoes, Link
Date 08/08/2016, Make NVidia Founders Edition, Rasphelt, Link
Date 08/08/2016, Make NVidia Founders Edition, Alphafox, Link
Date 08/08/2016, Make NVidia Founders Edition, Greebo, Link
Date 07/08/2016, Make NVidia Founders Edition, SherlockHobz, Link
Date 06/08/2016, Make NVidia Founders Edition, Scorpuk, Link
Date 06/08/2016, Make NVidia Founders Edition, dancook, Link
Date 05/08/2016, Make NVidia Founders Edition, Born_2_Kill_83, Link
Date 05/08/2016, Make NVidia Founders Edition, DmitryD, Link
Date 05/08/2016, Make NVidia Founders Edition, occuda, Link
Date 05/08/2016, Make NVidia Founders Edition, Kaapstad, Link
Date 04/08/2016, Make NVidia Founders Edition, Wulfster, Link
Date 04/08/2016, Make NVidia Founders Edition, whyscotty, Link
Date 04/08/2016, Make NVidia Founders Edition, waspy88, Link
Date 04/08/2016, Make NVidia Founders Edition, Combat Fighter, Link
Date 04/08/2016, Make NVidia Founders Edition, danielanthony, Link
Date 04/08/2016, Make NVidia Founders Edition, dshalky, Link
Date 04/08/2016, Make NVidia Founders Edition, Vore, Link
Date 04/08/2016, Make NVidia Founders Edition, spiralz, Link
Date 03/08/2016, Make NVidia Founders Edition, Starvald, Link
Date 03/08/2016, Make NVidia Founders Edition, Cosimo, Link
Date 03/08/2016, Make NVidia Founders Edition, blasterbolt, Link
To get on the Roll of Honour all you have to do is post a pic with your user name on it of your Pascal Titan X.​
First thing I try with my Titan X is the Battlefield 1 beta at 4K, but the fps is dropping into the low 50's and high 40's often. This is with no AA, everything turned down to high, no HBAO and resolution scale at 42. Bit disappointed to be honest.
Any way to definitively test if G-Sync is working correctly?
I am suspicious that either:
1) One of my Titan XP's might be defective
2) There is a possible bug in the 372.70 driver
3) Over clocking the GPU cores (by 200MHz) may be destabilizing G-Sync somehow?
Its a beta game with early Titan Nvidia drivers, I wouldn't be too disappointed; if 6 months after release its still the same performance I would be surprised.
That's what I thought, but someone else I have talked to is using a Titan and they could max it out and maintain solid 60fps. Could it be my 6600K? It's oc'd at 4.5.
Could I be added to the roll please?
Also I just want to add that I got the shipping notification the same day the card arrived, which was odd!
The Roll of Honour.
Date 08/09/2016, Make NVidia Founders Edition, Drojman, Link
I've been having a few problems with my 1080's and coil whine, so I am doing some research before ordering my next card.
What are the Titan X like for coil whine?
No coil whine here... but I didn't have any with my 1080s either - what PSU do you have?
I have a Seasonic 860w Platinum (XP2), it's the first time I've had coil whine. Now I've had 2 1080's with it.
I put my 980 back in my computer last night and it's silent.
Usually two GPUs like a 1kW+ power supply.
I think I noticed in your build log that you're planning a new higher capacity PSU?
Coil whine tends to be exacerbated when the PSU is being worked harder.
I'm only running a single GPU as I prefer a single card solution. I ordered a second card as the first one was so bad and that new card is just as bad.
I don't have any plans to change my PSU at the moment, as I've bought a complete custom set of cables from CableMod for it.
I was going to order a EVGA Classified card this morning but I've found out EK no longer make a water blocks for it.
Once I have a refund for both cards, ill order a Titan X and hope it doesn't have coil whine.
