- 29 Dec 2004
- Shepley
PYM CHAIR NOT PYMS
#pedant
#pedant
PYM CHAIR NOT PYMS
#pedant
PYM CHAIR NOT PYMS
#pedant
Damn Strava n00bs.![]()
GP4000sii's - for speed.what's the flavour of the month on here? Staying with Conti's probably. 23c![]()
Snug! Although my Defy is tighter at the top of the fork, I'm assuming you mean at the 'shoulders' of the tyre?![]()
Bit tight right?
You can get 'tyre boots'. I picked up a park tool one when the NFTO shop closed and they feel nothing more than a harder, thicker patch.Did spot quite a deep cut in my front tyre and a slight bulge as a result. Right in the middle of the tread. Is it possible to 'plug' bicycle tyres in a similar fashion to car tyres or is it going to have to go in the bin/turbo with less than 300 miles?![]()
Okay..you win. If you insist, that segment where you're a minute faster than me doesn't exist. I'll admit defeat![]()
You rode up it with mudguards (I'm guessing?) so don't give me too much credit!You rode up it with mudguards (I'm guessing?) so don't give me too much credit!
I got a front flat on some fairly new GP4000s IIs yesterday which was annoying. My second flat of the year and it was dry and an alright road surface. Not too impressed with that.
The 25mm P4Es I bought for Mrs OMS' CR1 are massive though and have no more than a millimetre clearance each side at the rear. I reckon 23mm will be a safer bet as the 25s are as big as everyone says!
back at it again with the same question, any REALLY waterproof overshoes around?
I'm on my 4th pair of super cool waterproof over-shoes that simply soak through like a sock lol.
on a different note, schwalbe ONE tyres are awesome! 1100+ miles and no punctures and imo grip is better than p4e's
I bought one of the proper tools and it is better than a big screwdriver, but only marginally. A better option I found was new chainring bolts that take a hex each side - easier to get tighter & undo. When tightening the others (with the tool) I damaged the heads as to me they were still not tight enough.Do I need to buy the proper tool for holding the back of them to tighten them, or can I improvise with a bigass screwdriver or something?
What have you got/tried?back at it again with the same question, any REALLY waterproof overshoes around?
