Enough porn to make a man blind. Stunning.
Motherboard screws changed.
RAM serial number stickers removed.
Graphics card PCB edges coloured black to match blocks.
What do I win?![]()
Looks outstanding so far Flix - The Nickel plating is the muts nuts
Stunning and insane in equal measure.
4 D5s is enough to blow minds.
Impressive to say the least.![]()
Excellent choice for the nikel plating, looking amazing.
Looking good (but eyewateringly expensive!)
What fittings are you using for the copper pipe and what size is the pipe?
I got my tubes back from nickel plating, it is sooo shiny![]()
If I just bent the tubes with my tool, the radius is too big, I had to improvise with bending by hand and things I've found
Would you mind sharing how much you paid for the nickel plating and where you got this done?
I'm going to be using copper in my next build.
What is the bending radius on your tool?
I'm going to use this...
It has a bending radius of 35.8mm. I figured that would be fine without needing to improvise...
drool drool very nice indeed,
I've got my Caselabs SMA8 coming this week and I really like the sLight nice touch and thanks for the link I will take a look.
Day
this is awesome, I thought the shiny copper looked good and suited the Monochrome theme, until you nickel plated those shiny rods! They looks absolutely fantastic!
I cant wait to see the end build
