Permabanned
- 23 Apr 2014
- Hertfordshire
Seemed slicker that 16 to me. Player runs seem better(through balls). Passing possibly seems a bit too good though.
http://www.moddingway.com/forums/thread-29986-post-103361.html#pid103361My conclusions after the first look are that FIFA 17 is almost impossible to mod. In best of cases we will be able to add textures but do not expect more than that. Modding FIFA as we know has ended. Forget about new teams, tournaments, etc. I repeat, if we are lucky we will be able to add textures and probably it will take long time until we find out how to do it.
I tried sticking it on ultra settings and was getting about 5fps.
Still looks decent on medium and runs smoothly on that though.
Hopefully, Frostbite will bring full 21:9 support.
Add to the first line
HALF_LENGTH=6
AI_SETTING_HALFLENGTH=6
First remove remove the 'USE_LANGUAGE_SELECT = 1' from lower down
Then add this at the top
STATE_TITLE_SCREEN_WITH_STARTBUTTON=0
TITLE_SCREEN_TIME_BEFORE_PRESS_START=0
STATE_LEGAL_SCREEN=0
LEGAL_SCREEN_DISPLAY_TIME=0
USE_LANGUAGE_SELECT = 0
AVAILABLE_LANG_1 = eng,us
I tried "The Journey" and it looks like it has everything I've wanted out of a Career mode for Fifa - I've been wanting something like this for ages![]()
Some tweaks for the demo
Open locale.ini in the /data folder with notepad
Change the half length numbers to anything you want, just be aware that stamina is set on 4 minutes so players will be knackered at half time
These cut out the gubbins you have to go through when you launch the game
Does the game just automatically run at 144hz if that's what the monitor is set to?
Can't see option in game to adjust it
