Is that wave over proximity sensor already enabled or do I need to switch it on?
It's in the display options.
Also if your eyesight is upto it I recommend dropping the DPI, makes everything a lot less chunkier.
One negative is you'll lose access to all your IOS purchases, unless you have a 2nd IOS device to use them on.
Do you have to use adb to change the DPI?
Yes.
All the instructions are in the link mate.
Apparently the newest OxygenOS firmware supports EE WiFi Calling. Can anyone confirm?
Wifi calling and VoLTE are two different things aren't they?
Hey could someone check if the Oneplus 3 is compatible with the Sky Sports Mobile app? Could be a deal breaker for me if it isn't.
Settings exist for that but I can't remember where. I turned them off. It's to do with emergency alerts.M
Bad Points
- I keep getting a message from Mobile Broadcast with my local area code in, a quick search suggests I'm not the only one and I haven't figured out how to get rid of it.
I wonder if these concern the camera or the display itself.3.2.6 OTA inbound..
Here are some highlights:
Fixed occasional green/yellow issue
Optimized white balance
source: https://forums.oneplus.net/threads/oxygenos-3-2-6-mm-ota-for-oneplus-3.465753/
