Caporegime
- 18 Oct 2002
Hi guys.Thinking of buying the Titan XP.Believe me it's been playing on my mind the past few weeks.I have 2 1070s atm running a pg348q 3440 x 1440.Would prefer the single card option tbh.Is the card as loud as some say?Also would it be a good upgrade from the 1070s?
I personally didn't think my 1080 FE was that noisy at all, esp upto 70% (which should keep your TXP fairly cool). If you want to go single card then it's a v good route to take considering your resolution, should last you quite a while
