- 13 Jul 2004
- Stanley Hotel, Colorado
You dont need HT for games afaik, some turn it off anyway. Depends what you are doing, check your core usage with the intel tool maybe
Ginganinja - I really hope that this - " Xeon 5650 @ 4Ghz (3.125 Vcore)" is not your vcore?
Am I reading that right!!
I think he'd be having a fried chip for dinner if that vcore was right![]()
Lol. I did of course mean 1.3125. Thanks for pointing out - will update my sig!
Ginga
Kelt - a question or 2 if I may.
I notice you have 4.4GHz and the same mobo as me. Are you able to set the mutliplier to 22 then? I thought that this was the turbo multiplier, and that it doesn't 'stick' if you set it in the BIOS.
Also, what Vcore do you need for that? Just so that I can compare my temps when I get the X41 installed.
Ginga
Yeah they run cool, especially compared to Bloomfield. That seems like a fairly high voltage though, mine does 4 GHz on 1.30 V and I never bothered trying below that.![]()
4GHz stable HT on 1.328 Vcore. Tried 4.4 required way too much of a VCore boost, even 4.2 was running toasty on a H50 (that being said the H50 is about 4/5 years old now) so I settled for a solid 4GHz and get about 66c max temp in a real world scenario. Quite happy with it for the price.
