well heres some data to show why.
i3 and i5s and dx12 almost half performance.so basically avoid using dx12 if you want the best performance.quite funny seeing how some were saying dx12 was better for cpu performance and how smooth it is in comparison.
50 percent drop on some card cpus cfgs ! thats some smoothness
http://www.techspot.com/review/1267-battlefield-1-benchmarks/page4.html
I'm sure nobody really cares any more but for completeness and my own curiosity I tested the 1060 in my 6600k rig, same settings DX11 Ultra 1080p, same Through Mud and Blood campaign benchmark.
All stock settings on CPUs and GPU.
i3 6100 = 71min. 84av. 97max.
i5 6600k = 78min. 91av. 102max.
So not a big improvement really. CPU usage again 90%+. 64p St Quentin Scar slightly lower fps than campaign like before but not much. I think there must be something more to the RX470-i3 6100 combo that we're missing. Would have been interested to see both GPU and CPU usage.
Anyway so long as OP is all sorted now, happy days.
I'd like to see a 6700k now ...get testing !![]()
One thing I'm noticing with my 6600k is that it's never going to 3.9Ghz, only seems to go t o 3.7Ghz. Could this be because my motherboard doesn't support the turbo boost or something
Well, the OP's problem seems to have gone away, just as mine did when I moved from an Intel dual core based system to an AMD quad.
Edit, I'm too slow.... ^^^^^
It will only boost to 3.9 on one core...
doesnt windows almost always use more then one core, program and background tasks
