Amazing what you can buy for sub £500 these days.
15 Sep 2016
As winter is closing in i thought it would be a good idea to take my little Polo G40 off the road before they start gritting. That meant getting a winter warrior for under £500 that would see me though in comfort with a good heater!
I Managed to snare this for £440 off ebay.
Ford Mondeo 2.2TDCI GHIA X
MOT until July, 4 new tyres, recent clutch, alternator,battery,brakes and exhaust
Its been remapped too.
Drives lovely, that will do me!
You check the MOT history?
I just did :eek:
https://www.check-mot.service.gov.uk/
Also if you look, the same ARB failure has come up (Aug15 and Jul16) suggesting it isn't actually getting fixed.
edit:
On a separate note I think they should give the MOT Test Centre Number on the website as well which would help.
I just did :eek:
edit:
lol holy sheep ****, i hope you plan on getting rid before july.
Yep i checked it. There is nowt wrong with it boys. I like to see stuff like that on an MOT it shows its actually had a proper one done!
Its £440... has an MOT, stops go's and turns. What more do you want! I work for Ford and my brother and dad are mechanics trust me theres nowt wrong with it!
People are mostly joking. :p
If you've given it a proper look over then I'm sure you know better. Most of the MOT items aren't really that worrying. I guess you got 4 new tyres and a new clutch.
No I guess not. Begs the question though why would the previous owner spend more than the value of the car in the last 6 months then sell it for dirt?
Probably because they woke upto the realisation they were throwing good money at it that could be better used on a new car in the long term - people often patch up a car they are accustomed to for quite awhile before making that decision.
Just got a new car after having this one for 4 years. I would guess he got tired of throwing money at it and decided to get something newer before another potential problem arises.
I did that with my last car as it was more important that I had transport and also didn't want to just throw thousands at the first car I saw..
So spending £500 on a car I knew I was going just dump in about 6 months time gave me some leeway
No, it tells you that the car is pretty shagged.
Wow, that's knackered. Hope it lasts you through winter :D
Apart from all the brakes need doing, the clutch needs doing, all tyres need changing and the engine sounds like a bag of spanners?
This
Have you actually read the original post...
