would be nice to have an option to 'drop-in' and ride with you for part of it too!?
Bawls, just realised that's the day I'm in Cardiff watching Wales v Japan. Would be back in the late evening so depending on time I could jump on then... What time you thinking of starting? Could catch you early sunday morning
It's so dark out now, all batteries were dying on me today. Di2, garmin and rear light!
Yup! This time of year is brutal on battery life (and my USB charger!). Really impressed with my Exposure Trace & TraceR. Using them as 'be seen' lights on pulse/flash and getting 15+ hours use of them between charges (45min-1 hour per day, so 3 weeks+ if I don't leisure ride!). My 'main' front & rear are only generally used in the evenings and are lasting over 2 weeks, that'll change once used in the morning (Cateye Volt 800 & Moon Nebula on solid).
First ride home since the clocks changed, it was proper dark. Most of it was ok but there were a couple of sketchy bits. I've put one of my dodgy Chinese torch lights on now, so hopefully that'll help tomorrow.
Really dark! There was a
good article on RCUK with a load of commuting lights options if you're in the market. Some makes/brands not even I was aware of for reasonable prices (FWE/Bontrager), although they're mostly 'be seen' lights. There was also
an article on Xeccon, a fairly new UK brand with some competitive looking prices.
Exposure Sirius mk5 & TraceR (550 lumen front) is a great bundle if you're after 2 lights with some real punch. Bought to replace my mrs' cheapy Aldi light (rated as 300 lumen and not as bright as the Cateye Volt 100 lumen she has) and I wanted something with enough power for pitch-black/bad weather. Charging isn't that convenient (unique cable) and there's so many modes she gets confused, but great battery life & typical Exposure quality built unit & mounting. The bundle is certainly a good option for features : brightness : price.
Had a decent session on the turbo this evening. Only popped on for half an hour cos the football is on. Felt much easier than last night anyway.
Had a good one myself too, just rolling around while trying to catch up with 'The Walking Dead' (S2!) before trying again to get my
InRide to calibrate. Try as I might to ride at 32.2 kph I just can't hold it long enough for the calibration to 'start' and prompt me to rolldown. I tried hitting it and doing the rolldown regardless in the hope one of the times it would reset it's '
Previous Calibration: 1.75' (quoted on screen).
No dice. Even with the last one!
My Tacx Vortex smart should get delivered today/tomorrow so that might be the last time I try. Paul you're welcome to the (working) replacement InRide if you want to try it yourself - won't send you the duff one for you to exploit their support!
Trust msg me! Note: you'll have better features/luck if running it from iPhone/iPad and not Android
Have a friend maybe interested in my Road Machine, if he isn't then someone online has offered me £130 excluding postage for it (postage is going to cost quite a bit I think due to the weight). Ideally I wanted £160 for it but I had priced that selling it with the InRide and the Vortex being £350 not <£320. Basically flogging the old Carrera makes my upgrade to a smart trainer about ~£75. Bargain!
Maybe it is the cold but my Moon Comet seems to be on it's last legs. Fully charged, 40 minutes on 50% flash and the low battery light was flashing
Hopefully that's an isolated incident!? Just started using a
Moon Nebula rear and very impressed with it, just not charged it yet! Was a bargain for half price late last spring... I basically have 2* 100 lumen rears now! (just don't run them max power)
