- 11 Sep 2013
I didn't say it did.Mileage increases do not increase the value of a vehicle.
Just that those of some higher mileages* are well past the point they'd have needed the common failures fixing, so are more likely to be in better order than the lower mileage ones, will therefore cost less in maintenance (because it's already been done) and will be worth more to the buyer than the lower mileage one that's likely about to cost him another 50-400% in a very short space of time.
I'm more familiar with the Golfs, but other cars and motorcycles work the same way.
Yes, but on certain cars those failure points are so common past X mileage that it's considered almost guaranteed to have failed, so any car still on the road and running fine well beyond X is even more certain to have had those parts fixed and be in far better condition with much more life left (an thus is worth more) than the car that is getting close to X, even though the latter has lower mileage.What does increase the value of old or specialist cars, is an excellent history with documented replacement parts and common failure points being addressed.
We actually do the same when assessing our assets at work, pretty much, although ours do tend to be more of a Trigger's Broom these days.
Is that clearer?
*Up to a point. There will be an upper limit too!!
