- 2 Feb 2010
- Crowmarsh
Sorry for asking a dumb question, is this problem including the GTX 980 EVGA Classified or any GTX EVGA 980?![]()
No its a different cooler.
Its 10 series ac3.0 cards only.
I have to be honest here and say that the "Thermal pad installation guide" looks like a right bodge job. It's actually laughable due to the fact that the pad inbetween the VRM's and the cooler looks like a god damn blanket. And whats the point because there is no pressure from the actual cooler fins. I don't even have words for the other thermal pads...
On a side note we had yet another 1080 SC go up in smoke at my place work today. This was just at the point of switching the system on with no load. Originally the system come back for black screening/Artifacts.
Anyway this 1070 FTW as been my first ever EVGA product and probably my last. Going to to take mine back in to work and see if i can get it swapped out for something else. I was hoping that EVGA was giong to go with the recall all cards as i heard mentioned at work but they decided that some VBios update was the answer and to ramp fans up which defeats the purpose of these later (And previous generation) cards being quiet under lower loads. And then to expect people to bodge their "premium" products (Premium price...) Pfft, i'm out.
I'm a little worried about using my card now.
Wondering if i should suspend using it until i get the thermal pads installed.
May already be damaged, who knows.
I think most folks (me included) ,will agree with you, to one degree of another.
I suppose you could consider it a "virtual" recall anyway. As they have said that they will replace anyone's card with an updated one, at no cost to the customer. Though obviously (like any manufacturer) it would be most likely with a refurbished card. EVGA are not alone in doing this. And "yes" I can appreciate people not wanting their new card replaced with what in effect is a second hand part. Hence why I shall be keeping mine and just doing the numerous"optional" fixes (sorry... Updates / improvements).
But I don't think a recall and everyone getting a brand new replacement card was ever going to happen. If only because this would have cost EVGA millions of dollars.
TBC
Just found out about this problem and have asked for the thermal pad kit,.
As I have to replace the thermal paste I would like to put a good one on,any idea what I should get.
What fan speed in both rpm and percentage does the new bios give at 70c on a 1080 FTW?
It comes included in the kit according to Gamers Nexus.
On my top EVGA GTX 1080 SC (in SLi) 70°c gives 68~70% fans speed at reportedly 4400RPMI don't know if that's a bug, but the card is quite loud at that speed.
Failing that, you could always try a re-flash. I found that this time when trying to flash, that both windows and my AV programming objected and that I ended up have to temporarily disable my AV programming to get it to complete the flash correctly. Even then (as someone else encountered) my fans initially, even after a reboot, were not spinning at all! Had to shut down PC an do a cold boot. Things seemed ok then. Never a dull moment.
Hi Sipha
Please see my update post #318 about the updates available to UK customers. Return to the UK address is confirmed Free of Charge now also as you would expect.
If you have not had a response from us please mail me with details. [email protected]
Of course guys here to help any of you that need.
Ben
Nope I havent noticed any change in the custom profile. I'm not sure these fans go up to 4400rpm, gpuz reports the same values as evga precision x.
