- 19 May 2005
Battery life has taken a hit on mine and my colleagues phones.
You need to give it a few days, Doze has been reset, optimisations all need to re-learn your usage pattern again. There is no way to gauge battery life in less than a few days.
I get VoLTE with WiFi off and WiFi calling with WiFi on.Just updated,
I'm on EE and get a VoLTE symbol with wifi on or off and wifi calling option switched off.
If I turn wifi calling on, the volte symbol dissappears and the wif calling on shows.
So in order to submit feedback, I need to agree to the "optional" marketing information?
yes, can the nougat beta be sideloaded or does it need samsungs help to keep going.
Just tick the first two and the next button works? Sure that is what I did.![]()
Just got the prompt to update. Wow what a wait that was!
@Oliver I'm sure you haven't dropped off the radar.
I downloaded the Odin version from XDA but then decided I can't be bothered to set up all my apps again, so I think I'll just wait for the OTA update now.
Has anyone here upgraded to the S7 Edge from a S6?
My reception with O2 on my S6 is terrible, I am buying out of my contract to get a newer phone and its really a choice of the LG G5 Or the S7 edge. I really want the S7 edge but im worried about the reception problems again....
My wife has a J5 Samsung. She is also with O2. If I sit both phones together, her Db rating is always about 20 lower than mine and I have the better phone!
