All overclocking is done via Overdrive, you can't change any performance features at all in the BIOS (on to that next) at all.
BIOS or UEFI is actually built into the CPU, so only AMD can update the "BIOS" or microcode. All overclocking must take place within the Operating system.
If it's anything like 5960x for $300 then that sounds pretty decent to me. If certainly be looking at upgrading my 2500K then.
"There are some errata issues present in the current testing samples, similar in a way to the TLB bug of the Phenom. The workaround right now is done via the BIOS. The workaround however, strips around 30 ~ 40% of the CPU performance."
And then went on to say...
"Performance is really good, be it SuperPi, Cinebench, 3DMark etc, it's FPU performance is incredibly good and easily matching that of what Intel offers."
"For Gaming, the CPU is neck and neck with INTEL, even at low res where CPU bound."
So what are they saying? despite a bug hampering the CPU's performance by <40% its still a match or better per clock, per thread for Intel latest CPU's in all aspects?
Bucket of slat.
I'll eat my hat if they release 5960x performance at £300. It's simply not going to happen.
No, they're saying it's with the bug fix disabled it's up there with Intel.
They ain't going to sell chips that are unstable and don't work so the fix will be in place.
And if as you read it 'only as fast as Intel without the fix' then as it will be sold with the fix the performance will be 40% less than Intel, which is not anything like good enough to even consider putting on the market, its only roughly about as fast as their existing FX CPU's, or a bit more.
Now, either there is something very wrong with that premiss, or there is something very wrong with the chip and AMD don't really have a product at all.
Its another 4 months until launch,so maybe this is why there is the delay from late 2016 to early 2017 for the launch as some pointed out here - maybe it is time needed to fix the bug??
I would rather AMD iron out any problems before launch TBH then rush it out.
Right, basically this....
Read about the Phenom TLB bug. It would be a stupid hack job for them to release these chips with a software fix in place only (the one that neuters performance).
If it is as similar to the TLB bug as the reddit poster is lead to believe, they can reduce the performance impact greatly by introducing hardware-based fixes or eliminating the bug altogether.
I don't like the sound of some of that stuff mentioned in that Reddit post, true or not. Particularly:-
I really hate software overclocking so I really hope this will not be true of the retail products. The bios has always been the best place to tweak overclocks. I also don't like the sound of not being able to update the bios and the fact that only AMD can is worrying.
How can the BIOS/UEFI be stored in the CPU anyway? the only way it could work is if motherboards were all identical spec? if true it sounds like AMD are locking things down pretty bad.
GPU's have a BIOS.
Why can't a CPU?
A CPU does not need to run VRM's, Memory IC's, fan controllers....... separate from those on the motherboard.
Missing my point.
A CPU could have a BIOS, while motherboard also has one (Controlling those elements you were questioning).
In doing so, giving the ability to lock down certain aspects of the CPU at BIOS level (Same as how a GPU has a BIOS, yet resides in a motherboard which also has a BIOS)
CPU's don't need their own BIOS for that, its not Intel's own CPU BIOS thats locking down none K chips.
Zen is a SOC though - it technically needs no chipset. But,OTH,I will have some healthy scepticism when it comes to an AMD launch - it would be nice if they pull of a good one though. If they get to Haswell levels of single threaded performance,that would be pretty impressive for them considering how much smaller than Intel they are,but it would mean either more cores for the same price or cheaper CPU pricing to compensate.
