- 17 Oct 2002
- Stoke-on-Trent
I have TitanFall 2, though I've not played it yet. The reviews I've seen have all rated it very highly and the SP experience is supposed to be brilliant.
Right, I've got no job at the moment so in between job hunting I need a new game to keep me going. I'm currently trying to complete Doom single player, and after that I have arkham knight to play but afterwards I am deliberating between fallout 4, titanfall 2, skyrim remastered, or the expansion packs for the witcher 3. I want a really good single player game to immerse myself in. Any recommendations out of those?
I have an XB1.. I get fed up with all the darn updates.. I don't want a 2nd console with updates to do.. Happy to use a PS4 for just offline gaming..
I'll update if/when I have to so I can play a particular game.. like PS3 which occasionally forced us to update to a fw to play the latest GOW game or similar.
going to upgrade my ps4 HDD does anyone know if the drives that are in the seagate portable external drives that argos sell work ok in the PS4 (either the 1tb or the 2tb drive). Was thinking of getting one of those to put in the PS4 and then put the 500gb drive into the case to use as a usb hdd.
Hi folks. Just looking to pick your collective brains.....
We are looking at converting our spare room to a cinema/gaming room.
We are torn between a projector vs a large TV.
So my question really is how suitable are projectors for gaming, particularly fast paced FPS like Titanfall 2? Would be looking at about a 79inch wide screen (width not diagonal), sitting 8.5 feet away. Cant really afford native 4k but would be a good 1080p unit.
As for a TV it would be a 65 inch native 4k jobbie. Probably a Sony but will have to research it. Not sure if i should go OLED or not. Im not overly brand loyal, I just like the best quality I can get for the money.
My main concern is screen response for gaming (will be PS4, maybe a pro as I might upgrade). Im used to a good response time. My PC screen is 1-2ms @120 hz. My current 40inch TV which I use for my PS4 is pretty quick too.
Any input appreciated![]()
What's the rough budget? Current/recent Sony pjs are the best option for quality/input lag at the moment, but there's some cheaper dlps that are decent.
My PS4 keeps ejecting disks. I tried all the remedies posted online but nothing works. The damn thing even turns itself on randomly and starts ejecting disks. Even after the disk has been ejected I can still hear the motor inside spinning and it's pretty loud. End up having to unplug the console. Rest mode or fully switched on, doesn't matter, it'll still switch itself on and keep that damn motor spinning. Oh yeah and it also keeps making beeping noises, randomly, even whilst switched off as well.
Tried calling Sony but they can't do anything unless I pay £125. Which I don't think is fair since the console has sat in the same place since I got it and never tampered with it. Got the console a couple months after launch from HMV.
Don't think there's anything I can do unless I pay which I'm not willing to do as I hardly ever play. Mainly used for streaming services.
If its out of warranty why would you expect them to pay? it sucks its gone faulty but not there fault either.
Used ones can be had for £100, or get a private company to repair yours but i know when i looked to fix mine they were charging way over the odds in end i fixed it myself
