Hate asking here, but well.
WIth the Nova Pro launchers installed, is there a way to change the pull down tray colour? Even just a darker shade.
My home button sometimes takes more than one press. I have it mapped to the Apps draw so it's used more than it usually would. Maybe this is why I notice the issue more.
There could be a background process also mapped to the button which causes a delay. Once the button responds and the app draw opens it works on every press.
Thanks, just wanted to quickly check it wasn't a fault before I installed the 7.0 update via Odin.
The notification bar?
I had to set the theme (under the phone's Settings menu) to Material Dark - this gave me a dark notification panel (and quite a few other sections of the UI) and fits in nicely with Nova.
I noticed a bit of a delay when it did finally come to life and saw the screen dim, I think it might be down to the auto brightness setting. I've set the brightness manually and it doesn't seem to be happening since - though it's still early days.
Just got an S7 coming from three with 12GB data works out to £33 a month, free phone. Not too bad... I know the Voda deal is being flown around but it is with 6GB data and I am quite data hungry....should last me the next 2 years - Phone is just for business purposes, email etc... I have a iPhone 6S Plus for personal
