If this deal is back on this Monday, i'm defo going to buy!
Is there any way for me to get an update to my phone when it's available?
It is back on the 28th December as already mentioned previous in the thread.
This may seem like a daft question but there are 2 fan cables for the fans on the aio cooler - where do these plug into on the motherboard?
Should one fan be on the cpu fan pins and the on another fan point?
Lastly, the fans have no direction of flow indicator on them! I intend to mount the rad at the top of the case with the fans below, are the stickers on the top or bottom face for this configuration?
ok ta, I've changed the fans around.
Bought a new case to go with this build - phanteic enthoo evolve. It has a fan controller with a connector that says to connect to cpu on motherboard. Ive connected that to the cpu fan on the mob and the 2 radiator fans to fan ports on the mob, hopefully thats ok!
Last Q! Where des the 3 pip cable form the pump plug into?
Ordered this.....then cancelled it as thought it wouldn't be much of an upgrade from my i7 3770. Since I've found I keep getting a semi when thinking about this deal so booked calendar reminder for 28th to order it again lol
If that is a k chip you won't have an issue selling in MM, just get the post count up
Ah ok, i wondered whether to use that for the ump! All changed round again!!
Appreciate the help!
It's arrived, gives me plenty of time to upgrade my PC in time for the party later
[grammar nazi] It HAS arrived, not it is arrived [/grammar nazi]
Nobody likes a grammar Nazi, you're not coming to the party
