Apparently there is a RX490 being released in December.
I just hope it is not a dual GPU card.
Thanks, Im definitely waiting now then.
If it were to be a dual 480 we'd have seen it already, surely?
That has been tried along with every other combination, it is very difficult to get it balanced.While it would be undeniably hard to implement l suppose, while not handle crossfire exclusively in hardware instead of software? Why don't they allocate 1 card for the left part of the screen and the second for the right instead of afr?
Star Citizen is most likely going to be pushing the latest tech and CryEngine 3 runs reasonably OK on AMD cards. ARMA3,not too sure about - its an older engine in that game,so might be still OK on Kepler. Hard to say - but I suspect from what I heard its more CPU heavy.
PS2,is more CPU limited on my system than GPU limited and that has not changed much whether I had a GTX660,GTX960 or this GTX1080.
Dual chip card would be 495, not 490. Besides AMD know that Crossfire is hit and miss. They are not going to claim it's good for 4K, then have to deal with all the complaints of misselling when only one chip is working and the performance drops.
Whilst we're on the subject, I currently have a 780 but going to jump to an RX480 because I've got a FreeSync monitor coming for Christmas. Will I not see much of an improvement performance wise?
How big an increase you see will depend on the game(s) you play, resolution and the 780 you are running i.e much bigger jump from an ok boosting "stock" a1 780 than one of the good boosting b1 variants.
For me why release a dual card polaris and a few months later release vega will be the same performance or more powerful.
Do you guys really think the 490 will be a dual 480 GPU? I mean Sapphire accidentally leaked it will have 8Gb of GDDR5 memory so 4Gb for each GPU which seems silly for a dual gpu card. Not to mention Polaris was only ever intended for mainstream users low to mid range. Ive never seen AMD release a dual gpu card for this audience. Dual GPU cards have always been targeted at enthusiasts being the fastest single card solution.
I can see it now... should i buy a 490 at x price? No might as well buy a 1080 for few quid more as it has more vram about same performance where xfire does work and scale. It's venturing into enthusiast territory.
With ultra settings 1440p getting ~130fps there on the 1070 so no way a 780 would with anything like those settings.
EDIT: Not running latest version of Vulkan though so possible it would be a bit higher with that.
