https://s25.postimg.org/j6f7jc2fz/IMG_8833.jpg[IMG]
[IMG]https://s25.postimg.org/lp0wk0o67/IMG_8846.jpg[IMG][/QUOTE]
How did I miss that garage :eek: So clean, tidy and big. I'm jelly... :(
Could you send a picture of your whole garage? For scientific purposes (ekehm... fap folder). :p
I'd give my left something for a grotty oil stained dark damp shed as long as it was big enough for me and the bike, for that lovely space I'd give up my first born.
Yup, as Freeman said, the British generally don't know what they're doing when it comes to garages (small, very often no power, nasty floors, etc.). I'd do anything for one of those American houses where the garage is bigger (or at least wider) than the house
A shiny floor is no doubt better. Any spill can be cleaned up without a mark whereas a bare concrete/other floor is just going to stain if you spill oil or something else.
My garage floor is horrible (rented place so I won't be doing anything about it), it's that dusty concrete stuff, so as soon as you lean down, you're covered in white powder. Plus it absorbs spills nicely![]()
In the next few years I want to buy a new place thats 90% garage, 5% kitchen and 5% bedroom, I will do my business in the street drain....
Sounds good to me
Nice big, well kitted (floors, lighting, power) garage is definitely priority when buying, or I'd at least buy something that I can kit out myself.
How did I miss that garageSo clean, tidy and big. I'm jelly...
Could you send a picture of your whole garage? For scientific purposes (ekehm... fap folder).![]()
Ignore the hate - it is just jealousy. Any one of us would give our left something for a garage like that!
Wow thanks fellas for all the compliments on the garage. All appreciated. BTW it was a complete DIY, and for not a lot of money either. If i can do it, anyone can. It was all featured here on the excellent online resource for garage floors allgaragefloors.com scroll down a bit and you'll see it featured there. I've had it since around Jan and its still as good as new. I do all my own work on cars and bikes. No hot tyre pickup, and trust me, where i'm from, tyres get hot hot hot !!!
Yeah, I'm still going with jealousy. Any half decent spanner monkey will reduce the risk of spillage and also have a spill kit handy in case he does spill a bit. That floor is a million times more pleasant to work on than some scabby concrete floor.
And it looks like treated concrete to me.
i always manage to spill oil whenever doing an oil change on a car...
Took my bike out for a ride this evening. It was a lot of fun and gosh it's powerful, but had my engine die on me when idle. It was at something like 500 RPM which is less than half what it should be. Found the idle screw and put it to just over 1k RPM, engine is much happier and the idle isn't faltering as much now. However I still need to sort out a speedo bulb and tacho bulb, plus I've a feeling my throttle might be sticking. Things to look at this weekend![]()
Yeah you want your idle about 1250 or so. Is the throttle stiff or notchy? If it's stiff some 3 in 1 penetrating oil dripped down the throttle and return cables will make it much smoother, the cables are probably the originals so 12+ years old. Make sure to adjust the throttle so there's no free play too, makes so much difference to how the bike will feel.
