- 29 Dec 2004
- Shepley
When you say "isn't working", what are they connected to?
How are you testing with the Nest if it's not connected to power? Just on battery?
Perhaps some pictures would help.
Thanks, one step forward two steps back it seems.
Existing programmer and stat wiring:
http://imgur.com/epNAn3d
http://imgur.com/CzHhmSy
I've wired the heat link in place of the programmer. When I hit the button on the heat link, the boiler fires but the radiators aren't getting hot. Clearly I'm missing something but I'm not sure what. Thanks for your help.
Thanks a lot for your help and patience! Feel like I actually understand how it all works now it just took a while to get there.
