- 18 May 2010
- London
Latest set of drivers seem good.
BF1 in DX11 is running sweet. Same for the Witcher 3.
Anyone else getting or had this before?
Can someone explain the 144hz flicker bug? Is this the flickering I see between rounds in BF1 with g-sync on or is that something different?
New set of drivers have just been posted: 376.19
I've always just installed over the top and haven't had an issue in years.
So im still having trouble with high idle clocks even after going back to drivers i know werent a problem, so figured id try the new drivers and it still happens. Weird thing ive accidentally discovered though is if i view a picture in windows viewer and close it the clocks go back to idle as normal....![]()
Same BUT every now and then i do DDU and sometimes i gain GB's of valuable space on my SSD presumably from it removing old instillations.
Do you ever clear out c:\nvidia?
The drivers stick a load of installation packages, etc. into something like C:\Program Files\NVIDIA Corporation\Installer2 as well :S
I agree its a strange one, playing games seems to be fine, afterwards it will drop to idle but if i watch stuff on youtube or stream it seems to almost always lock at 650 and only viewing a picture will drop it to 270.Logic suggests that your problem is not driver related. It's got to be a process running in the background.
Go to task manager and see what's set to load at start up. Try disabling all but the absolute essentials then restart and see if that solves it.
As of time of posting this there is a problem with latest set of drivers. They don't seem to be signed by Nvidia and they don't extract. Win 10 says they are not a valid .7z archive.
I am getting the exact same message for me too
