GSX beats the **** out of Dolby Atmos there - I really like the eSport mode though - sure it sounds horrid but the positional separation of every sound atleast for me is bang on so for competitive stuff it would be really good.
Got mine today so will be testing tonight, can I just disable everything to do with my SB-Z in the control panel and plug and play the GSX?
Ok installed with headphones and a few questions:
Windows Volume control options - I have to set this to "Speakers (Main Audio)" for any touch settings to work on device, is this normal Earphone headset sounds crap so guessing so.
What settings should I use for games like BF1, do I need any sidetone or reverb?
Bit underwhelmed by the Bass but that could be my HD555 headphone, though with my SB-Z the bass can be very good indeed so doubtful.
Do I need to set 7.1 in games or stereo headphones?
Correct make sure speaker main audio is selected, then go into configuration and select 7.1 and full speaker. Apply setting.
Config is ghosted out, maybe I've defaulted headset in control panel I'll check
Thanks for your help got it all setup right now, the surround sound is insane, never heard such distance or detail, when sniping in a windmill top floor I can hear some-one enter the wooden flooring downstairs with a diagnal downwards footstep. Would have liked a bit more bass, use to more with my SB-Z finely tune but the sound quality is nice and perhaps I did overkill the bass before a bit. Looking forward to getting my upgrade on headphones next to the HD599's.
I used to have the sound blaster z on balanced so my base wasn't over done, I hated the base setting on the SBz I feel it was way of the top. Would an 80ohm set of DT770's suit this?![]()
it's rated max 150ohm
No sound at all just a humSent mine back for credittoo many problems with BF1, so bought a Sound Blaster ZX instead.
Analog to Digital just made it worstNo sound at all just a hum
