Dont about moving Vcore around its fine at anything to 1.425v
So just have fun playing your games.......
This makes me want to go for 5GHz or beyond
we sold hundreds and hundreds of these RMA rate is no different to normal component RMA rate........................
The chance of any problme is very slim!!! Its been thought about and tested a lot. We will support in any case.
I already tested for over a month Kabylake bundles to replace this and other 8Pack Z chipset stuff.
No harm in him asking!
Got what i think is my final voltage, 4.6 @1.330v
Temps are looking pretty awesome now as well. Although not ran a long stress test or gaming session but enough to think its pretty stable.
Try and lower your voltage if you can. I'm down to 1.28v @ 4.6, it isn't stable at any less voltage or 4.7![]()
Odd,
Running Prime95 with the same settings puts CPU-Z at core speed at 4497.79Mhz!
Will just let this roll for an hour now.
EDIT: Prime failed. Core voltage override increased to1.35 - running again
EDIT 2: Prime failed Worker 4 after 18 tests and 48 miutes - 1 error 0 warning. I guees i need to bump the voltage a touch more!
