Which version is the latest stable Crimson driver before ReLive? As I'm some problems with the new drivers on my 480.
What problems you having?
Can you downgrade just by running the older installer?
Quick question. I've had RTSS installed for a while now (for capping frames), how do you get all the realtime info (cpu load etc) displayed with it. I've never actually used it for that. I gather you need hwinfo and that's it? Then what?
Thanks.
Thanks.
And ANOTHER blue screen video freeze (that's two in less than two hours)! Both since updating to 16.12.1
Seeing as the last catalyst driver was released over a year ago no none at all
Oh!
The interesting thing was, my existing driver was reported as 16.40 (or 16.140) when asking should it update to the later 16.12.1 ones?!
Rolled back to 16.7.3 and it's perfect.
Problems I was having is my 290 core clock fluctuates all over the plaec when gaming, playing Shogun 2 yesterday and the clock was dropping to 300mhz at some points causing stuttering so I use gpu tweak to force max clocks, gpu tweak refused to work with the relive drivers and I had two system lock ups.
16.7.3 and gpu tweak from asus is perfect, have a keyboard shortcut for max clocks and desktop clocks.
That is weird.... when you say asking should it update do you mean the driver is giving you a notification?
 (Even with these downclocks!)
 (Even with these downclocks!)How old was your previous driver?
What temp is your card running at?
Its probably quite an old card if its a 7870 do you keep it clean?
With a 7870 I think you are best using afterburner for clocking and fan control as I think you are still stuck with overdrive within the drivers
Giz
Thats pretty old - did you choose the clean install option when you updated and did you close afterburner whilst you did it?
Drivers might have reset your fan profile and if you are running an old version of afterburner you probably need to update that as well.
65 degrees is very low your fans are going to have to work hard to keep that temp
Giz
Rubbish drivers, don't know why i bother ever upgrading. If it isn't broke, don't update that's my new moto.
