When are you going for stage 2 or beyond?![]()
Been tempted a few times. It's minimal gains in terms of power over what I have now, though, and it'd be at least 2k. The noise of a downpipe/proper intake system/full turboback exhaust on the other hand...![]()
Are my costs out then? Already got the intercooler. It is tempting if I could get it done!Going to stage 2+ is like going from stock to stage 1
You'll only need a HPFP and other bits and bobs really, just decat the main down pipe and add a induction kit if you'd like. I'm running 450hp and 749nm on mine at the moment.
Nice power!
Do you have any issues with prop shaft bolts shredding or is that only a risk on hard launches?
Finally, some real talk in the thread, no talk of diesels![]()
There are a lot of 800hp and even a 1000hp rs that run on stock drive trains with few issues.
How are the 2007-8 era S3s? Been looking at those recently. Even high mileage ones seem to be in good condition, but you never really know. Wanted an S4 (4.2 v8) but like someone said earlier, the potential for engine problems and crazy repair bills scared me away![]()
Planning Stage 2+ next...Any A4 B9 owners put a dashcam in their car yet? I dont want to start pulling trim away if I can avoid it.. any ideas of the best way to get the charger from the 12v and away from danging around the cabin?
I have one, overall I'm really pleased with mine. Stock they are far from quick and going Stage 1 is a must (feels like what the car should have been from the factory). Currently mines sitting at 335HP and 450NM torque with a Stage 1 map, full 3" Milltek turboback exhaust and Revo intake. Town MPG hovers around 28/29 and I get around 35 MPG on motorway run, not bad for the power but who cares about MPG anywayPlanning Stage 2+ next...
In terms of reliability the TFSI manual drive train is pretty strong. I've had zero problems with mine so far, saying that the usual applies (breather pipes etc). There have been a few stories about the high mileage DSG boxes failing (mechatronic failure irrc?) that require dealership work (and dealership costs - thousands!).
Cam follower needs to be changed and checked every 3000 miles ish... (£70 parts and labour) and the rear wiper motor sometimes goes because it fills up with water (pretty easy to replace yourself).
Seems extreme. I bought my '07 S3 on 110,000 miles and sold it on 126,000 a year later and never once checked the cam follower. Spent a lot fixing it because I bought it with some issues (wheel bearing, aircon compressor packed up, etc), but other than that nothing broke in the year I had it and I drove it hard. Didn't really use much oil either, considering the horror stories you read regarding the 2.0TFSI.Cam follower needs to be changed and checked every 3000 miles ish... (£70 parts and labour)
I don't really miss it. I miss the speed and the grip in *all* conditions but otherwise it's just a fast A3 with hard suspension.
But I agree with the above 2 posts, its a fast hatchback but not massively exciting to drive. I took mine to Bedford Autodrome a few months back and while it was fun to throw into corners it just didn't feel that exciting - don't let this put you off however as its a very good all round car
It's on my list of things to work out so will try and take a look the weekend. My current plan is to take power from the reading lights.
Is oil consumption an issue on the S3? I hear some people have to use about 1L per 1000 miles in some VAG cars, which is just terrible. Considering my Fiesta ST never looses a drop!
