Caporegime
- 18 Oct 2002
make some noise = loud fans + coil whine![]()
Coil whine on the Name, pump whine on the X. Take yer pick!!!
Yes, Vega is coming
http://ve.ga/
They're trying to drum up support.
It isn't that unusual for AMD - Hawaii (290X) and Fiji (Fury X) had quite a lot of hype upto launch as well - much of it subsequently swept under the carpet :S
That is why i never buy AMD product and will not ever buy. There marketing team mocks a company ,which has 5 GPUs faster than its best card. They are mocking and trolling a company ,which nearly bankrupt them in 2014. Still AMD PR is filled with 16 years old brain child, which is why teenage group are majority of AMD fanboys.
Can't tell if you're serious?...
Shots fired !
'Poor Volta' Lol, go AMD xD
That is the thing ,which i am talking about. They do not even have card ,which can beat Pascal high end and they are talking about Volta in their AD.
I thought amd showed us vega running at faster than 60 fps at 4k resolution in starwars battlefront.
Ok they didnt say what setting were used,but i doubt they would have used anything below very high settings for the demo.
Also the drivers used were not optimised for vega.
So i would say vega can match high end pascal,and maybe beat it.
I am telling you the reality that AMD do not need any enemy because AMD PR and their fanboys are enough for that.
