How much did it set you back mate? I've just watched a few videos and I'm super keen now...
Help me everyone.
I got a small 15 quid micro quad for Christmas and loved it. However the corner motor died after what I suspect was a crash indoors... And now it won't fly.
However I want to basically get something for around the 50-80 quid mark to mess with.
What's the best value for money option.
I've got a Syma X5C-1. Great fun to play around with and get used to the controls, found it really durable as well. Can be had for around £30/£40, spares are cheap as well and can get about 10 minutes out of a battery.
Try a simulator to understand the basics of flying in rate mode - The DRL sim is free and is quite good (if a little floaty)
My QX95 feels pretty different to my 220 size when flying
Now programming the radio, but having some trouble as the throttle, pitch, yaw and roll are all inverted and no matter what mode I choose I can't seem to get them to the correct setting.
So my QX90 came yesterday. After messing around getting it to bind to my Flysky i6 I adjusted end and mid points. For some reason Aux2 is linked with Throttle(chan3) I cant figure out why so just added angle mode to aux2 for now.
However when attempting to take it it just spins off to the side, I have calibrated in cleanflight and double checked end and mid points all ok at 1000 1500 2000.
I think I may flash Betaflight 3.0.1 as that is what is running on my proper quad.
Anyone have any ideas or suggestions would be great!
Thanks.
