Starting discussions about listing Ubiquiti gear. Is there any products in particular that people want to see so I can prioritise?
The Edge Router X is a good upgrade from a Hub 5. Definitely more reliable but significantly more complicated to setup.
You can also power the Edge Router X with the injector from the AC-LR and then pass it through to supply the AP.
On my Asus router I can use mac filtering to block devices from connecting to 2.4GHz since most devices aren't very smart about staying on my 5GHz network, from reading the Unifi stuff doesn't support mac filtering at all?
Cheers.
What details need setting up on the ERX? I've done a Google search but mostly brings up CLI configs, would rather do it through the GUI if possible.
anyone got the cameras running? how you finding them?
.Easy enough. Even easier if you're either decomissioning the current VM Or can change it's IP address.
What I did recently was:
- Grab a backup out of your current controller
- Shut down the VM (or change IP address and disable the Unifi service if keeping the VM)
- Fire up CK
- Set CK IP address to match what the VM was using
- Restore the backup from the VM into the CK
That worked fine for me.
I've got a 3 pack sat on my desk, but it will be a while before I can get them up and running.
Cheers.
